BigSteve22
A little background first. The neck for my Jazzmaster went to Cagey to experience his tender loving care and excellent fret work. This was a two fold decision: First, I wanted to see for myself if his repute matched the actual finished product. (No doubt about it, it certainly does! As I said, excellent work.) The second reason, was that although I enjoy the therapeutic rewards of doing a build myself, I had found neck work to be a challenge, mainly because I had trouble keeping the neck solidly in place while working.
So this time around, I decided to do things right, and build myself a neck fixture.
It's got a maple bed with 2" poplar spindles on each end that sit in poplar pillow blocks so it can turn to any angle needed. The mounting surface of the bed is level with the central axis of the spindles. This is mounted to a board which can be clamped to any stable surface.
One spindle can be locked in place to keep things from turning unexpectedly.
The neck mounts to the bed using the standard mounting holes and rests on cork pads to protect the finish.
So, on to the frets. I adjusted the truss rod, and checked the frets for level. As you can see, Warmoth's fret install is pretty damned good right out of the box.
Using a fret rocker, I did find 2 very slightly high spots, center line at the 4th and 7th frets. Everything else was fine. So I used an extremely fine fret end file and just barely lapped these spots until they were almost where I wanted them. (Because the amount they needed to be taken down was so small, I was able to maintain the crown by moving the file from side to side as I went.) I then brought the frets down to final height using 1000 grit abrasive paper.
When that was done, I taped up the whole thing so I can go to town on the fret ends. That'll be my task for the week.
I couldn't justify, (or afford!), the price if Stew-Mac's "Erlewine Neck Jig", but my poor man's version at least gives me a leg up over just sitting it on the bench and hoping for the best.
