warmoth lists its standard thin contour at .800 at first fret and .850 at 12th fret. i hear this is quite similar to the fender modern C.
gibson's slim taper is supposed to be .800 at first fret and .875 at 12th fret.
as i find the upper frets of the standard thin to be a bit thin and the slim taper to be a bit hefty, i was wondering if .862 (right in between the standard thin and the slim taper) at the 12th fret would work fine?
or would it adversely affect some other dynamic?
and does the fretboard radius have any effect on the contour? or would any radius work with any contour?
appreciate any insights.
