BigSteve22
Very nice axe, glad it worked out for you. Best of luck with your new toy! :icon_thumright:
Just as a point of info, I had no problems at all with the Babicz Z-Series Tele bridge and a standard thin profile neck. Had plenty of height for my application.JD0x0 said:I had this issue with some bridges.
La Cab- American Standard strat bridge. Just barely got the action high enough with the saddles cranked up to their limit.
Gold babicz full contact tele. Strings were laying on board with height maxed out
*Chrome babicz full contact tele - This one actually had no issues..*
weird right? The one with the action issues had a Clapton contour neck, while the one without issues had a 'boatneck' not sure if that made the difference.
M2.5x25mmBigSteve22 said:I replaced the intonation screws on my Z-series Babicz tele bridge, size is M3-.5. Can't swear the "Original" series uses the same size, but 89 cents and a drive to your local heme improvement center is all it would take to verify..... Good luck, please let us know when you do find out for sure.
JD0x0 said:M2.5x25mm
The 25's may or may not be too long depending where you need to have the saddle. 18mm-25mm length seem to be the ballpark.
