Re-Pete
Street Avenger said:Re-Pete said:I must have accidentally wired the old one in a parallel setup as it sounds rather jangly - somewhere between a Gretsch Filtertron & Rickenbacker toaster pickup tonally - in sound when the tone is boosted.
I don't think it's possible to "accidentally" wire a humbucker in parallel.
OK here's what I think happened. [I'm happy with the sound I'm getting btw, so if it's a goofup on my part then it's staying as it is...]
You have four wires from the pickup. Two are supposed to be tied together to make a series connection between the two bobbins.
I think what I did, was tie up the wrong two wires & somehow achieved a halving of the power output by placing the bobbins side by side to each other [parallel], instead of joining the bobbins end on end to double the power [series]. :icon_scratch: :dontknow:
In my defence, your Honour, I submit that 2 pickups from 30 years apart can possibly have different colour codings for their pickups. I used the current codings from the Wilde site & got both pickups working first try. That was good enough for me & the extra flexibility of the jangly neck pickup was a pleasant surprise.
Late Edit:
Check out this switching arrangement of four conductor wired humbucker pickups... Parallel or Series. All I have probably done is permanently wired in the parallel arrangement without any switch..
http://duhvoodooman.com/musical/humbucker_mods/series-parallel_switch.gif
Darnit, now I have an idea to add 2 switches to switch out each pickup into either parallel or series.... Must resist, must resist....there's enough complexity on this guitar as it is.... must resist... :help:
