Strat Avenger
'Anyone here have experience with a humbucker (especially neck-position) wired in parallel instead of series?
What is that tone like?
Kostas said:Stonker said:... For crunch, I do quite like the SD Alnico 11 Pro (Not the Slash ones) from what I've heard on YouTube...
Have you tried both or your opinion is based from online clips only?
Cagey said:In my experience, most "humbuckers" will sound clean if you just back off the volume on your guitar a bit. Having two coils in series increases the pickup's output which tends to overdrive many amp's input and causes distortion. Sometimes that's desirable, but you don't have to use that characteristic if you don't want to.
As Stubhead has mentioned more than once, you really want to dial things in with your guitar's volume/tone controls backed off a bit so you have somewhere to go. If you rack everything to 11, you're not only already at the wall, your EQ and SFX are somewhat limited as well. Turn things down from full-tilt boogie and you lose all your tone.
Jumble Jumble said:That sounds fascinating. Please do keep us posted, I'll be really interested to hear how that goes.
