Cagey
Mythical Status
beltjones said:PRS himself has said in interviews that choking out isn't an issue with properly done frets and a well set-up guitar.
I'm not PRS, but I can attest to the efficacy of that radius and string-risking bends without fretting out or buzzing because I've done it. But, it does take some meticulous attention to the fretwork, which very few manufacturers will spend the time to get. It's the old 80/20 rule at work. You can get 80% of the fretwork done in 20% of the time, but that last 20% of perfection will take 80% of the time. It's rarely called for and unless you're using stainless, it isn't likely to last, so it's equally rarely done. Plus, that radius is rarely called for. Something a little flatter or better yet, a compound/progressive radius is much easier to play.
