whitebison66
I didn't get any photos of this one in process, since it was a mighty struggle.
I glued up an 8/4 blank from 2" Philippine mahogany planks. Then I used a router jig to 'plane' it flat. Cut out the shape, then hogged out most of the middle with a forstner bit for weight reduction and sound reasons. I used hobby shop cherry planks that were a little over /16 thin, glued together (that was fun) for the top. As part of an intended-but-abandoned theme (and to be different) I made the F-holes into sabers. Why not?
I made the neck myself from PM, and used a mitre box/chop saw with a jig for the angled headstock.
I really need to invest in/make a bending iron, because that maple binding deserves better than what I did with it.
I cut out the truss rod cover from the headstock veneer.
I did the finish, which has an incredibly subtle burst, by hand with stain and a rag. Rattle can nitro finish.
I see all the mistakes, but it appears to be holding together, and I made it to play, not look at.
And yes, I hope I can update this thread with finished pictures in less than 4 months too!
Bound the headstock and the fretboard with maple.
I used side markers for face dots; very discreet but still very visible.
I didn't like the height of the bridge off the face of the guitar (4 degree pitch for the neck), so I fabricated a walnut bridge plate. I think it looks okay.
I used a Bigsby copy I bought in Japan last time I was there and the Stew Mac roller bridge.
I used maple veneer on the pickup covers. Looks great from 4 feet away.
I realize the headstock is small, but I wanted to get straighter string pull.
