Superlizard
Crate amp FTW.
Oh yeah and this too:
It totally r0x0rs.
jimh said:AprioriMark said:jimh said:'72 refurbed (by me) Fender Bassman 100 head
If you don't mind my asking, what did you do to it? I am always blowing transformers because of heat. I love how the thing sounds, and mine is ugly as sin, but I have never found anyone who could make this thing not EXPLODE from time to time.
-Mark
Randomly I saw it in a shop. I wasn't looking to buy an amp, but had to 'have a go'. The guy plugged it and switched it on, but one of the valves (sorry,,,,Tubes :icon_tongue: ) Didnt light up. 4x6L6s. Didnt bother me as there's nothing terribly complicated inside these things, so I made the guy a stupid low offer since it was broken. He accepted the offer, and I walked away with it.
Got it home, and replaced 1 large resistor which had cracked completely in half and the valve lit up and hey presto I got some audio. So the amp was working.
BUT, I then got a whole new set of valves, pre and power. The amp was pretty noisy and crackly, so I cleaned up all the pots with some contact cleaner, replaced the big power supply caps which were looking a bit worse for wear. I took out the strange bias balance circuit and replaced it with a regular variable bias circuit. Biased the new valves, plugged in, switched on and rocked out.
My Transformers are original but look to be in pretty good condition, so I dont really know how to help you there. Are your tubes biased properly? They could be working too hard and pushing the tranny past its comfort zone?? I'd have thoughts it pretty unlikely as Fender used to go overkill on the transformers. Correct speaker impedance? Mine has a fixed 4ohm (non-switchable) output transformer, so I rewired my Orange 2x12 for 4ohms (2 x Celestion V30s 8ohms parallel). If you've got a speaker impedance mis-match that would definitely blow your trans.
Mine sounds brilliant now. No noise (apart from a small hum when its cranked up really high - you get that from any valve amp regardless of how new or old it is). Really powerful, clean up until the about 6 on the master vol so you can really hear what the drive pedals are doing. Its classic fender clean yet pushy (not drivey, but pushy, cant really find a better way to describe it), but it will break up nicely if you really crank it. Loud as hell through my Orange 2x12 though.
Superlizard said:![]()
Crate amp FTW.
jimh said:Torres Tiny Tone
Ceriatone 1987 'Plexi' 50
Cornford Hurricane
Orange 2x12 Celestion V30's
Laney 1x12 with Celestion Greenback
Crate amp FTW.
It totally r0x0rs.
big bob said:did you get that amp from Chrisguitar?
big bob said:jimh said:Torres Tiny Tone
Cornford Hurricane
did you build the tiny tone, any thoughts?, I'm itching to build something!
Yep, I built it from a kit. It sounds great, buts pricey. I got it before I knew about the other kit makers. If I were you I'd look at the ceriatone stuff first. Don't get me wrong, the torres is good but other makers are better. IMHO.
jimh said:Sorry if that last post looked weird. I'm usin my iPhone on a train, and the web browser wouldn't let me see the reply box properly
stubhead said:I've owned a lot of Marshalls, and every one was different - even the ones that were the same! :toothy12:
MUYFUE said:I use a Trace Elliot Bonneville head through either one or 2 Mesa cabs, one's the oversized Recto with V30s and the other is the regular sized with black shadows. Usually I just go straight in, or throw a Crybaby Classic in front. Sometimes I'll put in a trace 7 band eq in the loop.
muttznmongrelz said:I almost bought a Trace Elliot Tramp a few years back. Sweet little amp.
MUYFUE said:I had the Tramp full stack...sounded great!
I wish I hadn't sold it...but I used the money to get my Mesa and BANG!
The Tramp 2X12 combo is Fab-U-Lush!
