Mnemoflame
At some point in the next two years, I'm planning to build a Strat through Warmoth but I have a wealth of questions that research just isn't answering satisfactorily. The plan is a chambered indian rosewood body with a walnut top configured for H-S-H (DiMarzio D-Activator bridge and neck plus a DiMarzio Chopper in the center position) and a Schaller 475 flat bridge; I'm aiming at wood mounting the pickups a rear rout and for standard Strat controls (I want to avoid the pickguard to emphasize the beauty of the wood), though I mean to use 500k concentric pots for more independent pickup control, and three 3-way switches for coil tapping (series in phase, some kind of single coil arrangement, and series out of phase). I was thinking of an indian rosewood or walnut Strat neck and an ebony fingerboard with stainless 6100 frets; I'm looking at the Planet Waves self-trimming tuners and the LSR roller nut to support my nasty alternate tunings habit.
My questions are as follows:
-How is indian rosewood for a body? What difference does it make going with a two piece body vs. a three piece? Chambered vs. solid?
-Indian rosewood or walnut for the neck? I was thinking rosewood for consistency but walnut seems like it might be a better choice tonally to counter to the warm tones of the body.
-Is an array of three way switches the best choice for the sort of coil tapping I want to do or would it better to use two sets of switches or buttons so that out-of-phase and single coil settings could be used together? Is either idea even possible with the pickups I chose?
-What other parts will I need besides what is already listed here? Are there mounting rings for Strat-style pickups like there are for humbuckers?
-What's the best setup for the five-way switch? I was thinking neck - neck+center - all three - center+bridge - bridge, figuring that I could turn the appopriate volumes down/off in the middle setting if I want a center-only sound.
-What else am I missing or not getting?
I'm a total noob to this so I would very much appreciate the advice of those more experienced. My general goal is to have a versatile, well-rounded instrument with as much richness of tone color as can be managed with pickups suited to playing metal; I'm studying fingerstyle guitar and aiming at eventually playing general rock and metal kind of things.
