a Floyd TELE build
An interesting idea Mr Hendrix. Did you also use an Acrylic varnish to seal the pores of the Acrylic paint ?
I use acrylic varnish mix with acrylic color , so it is semitransparency , can show the wood grain even with thick coating .
I have put body in drying cabinet for 2 weeks to made it as dry as possible before paint it.
Thanks, those paints are available also in varying degrees of opacity I noticed. But even when dry has open pores, so the Acrylic varnish acts as a seal, which is why I asked. I would think the varnish mix will do a similar job or a varnish coat to finish is also an option.
Look forward to seeing the rest of the build.
That's one of the nicest contemporary Tele builds I've seen since Rob Rounds' "Blue Jean" tele.
DBU will be proud that you stuck a Floyd in it too! :headbang:
Stellar fretwork I might add! :occasion14:
to made flat jack cup perfect fit with telecaster body , some delicate bevel edge on the jeck hole, need to be cut by electric rotary .
some gap on the side without bevel edge .
mark the line
rough bevel edges grinding
sealing the exposed wood
Whoowee! Abner, I think thar's a revolooshunerry messin' wit our Telee-caster....
I don't know how much internet poking around you've done, but one of the oldest, most respectable and really, quite a ducky place of sorts is "TDPRI", the... Telecaster.. Discussion... People? Really... Interested? Actually, I don't know what the heck all those letters stand for, and apparently, neither do they. But they do have a subset of people who can very seriously discuss just how "real" a real Telecaster is, and how with the right aged, improved vintage, even-more-realer-than-real parts from Rutter & Callaham & Barden etc. you can make a guitar exactly like Leo Fender would have, had he only been as cool as they.... I'd bet they'd get a real "bang" outta that babe! Whoowee! Activate force-fields & flame-shields prior to posting....
http://www.tdpri.com/forum/index.php
on the other hand, malcontents and the lunatic fringe from four* continents mumble, stumble, burble & lurch about rather freely here....
*(make that FIVE now, if we don't scare you away... or vice-versa! :o :o )
Can't be 100% sure, but I think it was called TDP, Telecaster Discussion Page, and then the site went bang. When it was brought back it wasn't the original any more, but a reissue - hence RI.
I already said " it a kind of Tom Anderson/ Suhr tele I want to build . " . is TA/  Suhr need to build "real Tele " ? it not anything new.
fender.com has 106 guitar list under telecaste page , which on is more real ? :guitarplayer2:
I also got this one too , it also not real :
I'm not sure which one of my "Tele's" counts as LEAST real.... :hello2:
The one with the scalloped fingerboard and the Lawrence L500XL fire-breathing dragon pickup, the... umm... little one, or the tin-can one, which is, notably, the only one with a "real" Fender body.... in the land of TDPRI and the Steel Guitar Forum, these are known as "tele-shaped".... :toothy12:
Jumble Jumble said:
As far as I'm concerned, Teles are like art: if someone says it's a Tele, it's a Tele.
Hehe! That's me, too. But, I'm sorta forced to that attitude as none of my Teles would qualify as Teles if conformity was any criteria, even though Fender has 100 bajillion models.
It's the silhouette of the body really, I guess. Any non-trivial departure from that means that nobody would ever identify it as a Tele. For example:
You can see that it's got Tele influences, but I don't think anyone would argue that it's still a Tele at this point.
some updates:
I don't like the sound of the pickup previously use of this Tele, so I updated it with Bare knuckle. VII neck pickups, Aftermath bridge pickups with Burnt Chrome Bolts. Coil splits Mini Switch.
Round Top Knobs with the DIY copper finish.
All I can say is, regardless of what it sounds like, that's an outstanding instrument!
