a few questions on superglue
doctor-dave
i'm currently 2 coats in with a pretty light superglue finish on my guitar (LP5 in work in progress), and i was wondering, because superglue gives such a strong finish would it be wise to do all my drilling before i put anymore coats on? and if i do drill, what would i do to clean up the holes - and strings thru? should i use a drill/dremel and bore them out a bit?
also, is it best to do a light sanding with 320-400 after every coat has dried, i read somewhere here to do like 15 coats then sand it after
thanks for your time
oh also im thinking of getting a set of koa pickup rings from www.pickuprings.com - does anyone have any feedback on their service?
doctor-dave said:
...because superglue gives such a strong finish would it be wise to do all my drilling before i put anymore coats on?
I would wait until I was finished.  Superglue isn't going to stop a drill bit.
doctor-dave said:
...and strings thru? should i use a drill/dremel and bore them out a bit?
You may have to do that.  Or get a wooden dowel from a hobby shop that is about the right size and wrap it with some sand paper to use as a sander.
15 coats of superglue?  I've not actually heard of anyone using superglue as the final finish, so I don't know what to tell you about this.  CB has a good post about using superglue as a filler in the DIY Finishing section, it will probably be useful to you if you haven't already seen it.
I've only used them once, but they were excellent.
JBD
