6875 Mod...... ?
Hagwood
When I was test fitting my neck before the final sanding/polishing (Purple Burst Musiclander in Builds in Progress), it seemed that it was sitting too high. I measured everything and it checks out – 5/8” pocket, and slightly over 3/8” fretboard height above the body (10.25mm). But it just looks funny to me. Maybe I’m not used to 22 frets on a non pickguard body, but it really just seems like a huge gap.
So I was researching the 720 mod, and it sounds like it can cause issues with geometry, but what would the ramifications be of making my own say .6875 Mod by just lowering the neck pocket 1/16” ? It will have a Hipshot Hardtail.
Maybe I’m overthinking it, but I do have that tendency…..
Hey bro nice guitar! I have had this issue myself on some Warmoth necks. I have carefully sanded the neck itself (FLAT) until the cute turtle disappears so it sits lower in the pocket. Out of 10 necks, I have done this 4 times. Worked for me, but it could be a dicey endeavor depending. I don't like my saddles sitting way up at an angle.
Thanks ! My thoughts exactly, It seems with that low profile Hipshot they will be up pretty high. I was thinking either sanding or maybe using the little router to barley go down about 1/16", but I like the idea of just taking it off the neck. I appreciate the idea.
Just be CAREFUL. FYI, I have had to do this when fitting Warmoth neck to both Warmoth and non Warmoth bodies.
AFAIK, modern Fender Strats have the neck pocket depth of 11/16”. I think its a good idea for hardtail bridges so I’d be in favour of an alternative neck pocket depth of approximately 0.6875”, or “680 mod” etc.
Never had to do that with a Warmoth neck, that said, be careful, if you shave off too much, or are crooked, note that you'll be paying school fees.
Ya, it's not for the faint of heart!
Ahh, thanks for that info !
I did your suggestion last night and just shaved about 1/16 + inches off the neck itself and it looks great now. Was scared to use the belt sander, so just did it by hand on a flat surface and mic’ed it along the way. After a little adjusting, it’s perfect. Easier than my first thought of using the little router on the neck pocket……
Thanks for all the replies guys.
I did orbital, then finished by hand checking with calipers. Goodon you sir!
As a side note, I tried something different on this roasted maple and used micro mesh up to 12,000 grit. Man it feels fantastic and has a nice sheen to it. Nothing like a finely sanded raw wood neck with no finish……
@Hagwood if you use the icon along the top row of the post that looks like a photo between the chain and smiley emoji symbol, your photos will show up in the post rather than as attachments. This will make them easier to view.
Thanks for the pics. It’s not really clear to me how 8.1mm is measured. Is it from the top surface of the body to the crown of the frets?
Thanks. No, from the body to the top of the fretboard. Supposedly it’s supposed to be 3/8”, which is 9.5mm. I don’t think it’s an exact thing, since it would be different depending on where in the radius you measured. Mine was sitting at 10.25 which seemed really high, so I was shooting for 8mm. More for reference of how much I was taking off than worrying about exact numbers. Close enough…….
