W
Watershed
I wanted to do a brief write-up on Z Poxy finishing resin as a filler/sealer.
I tried some of this stuff from LMI a while back and had great results with it, so I thought I would share.
I thought it deserved some attention because it is pretty simple to work with, and makes finishing open grain woods very easy.
It only needs about 24 hours to dry, and exhibits very little shrinkage.
It's obviously not the only filler/sealer out there (I know some out there have there favorites), but it's something to consider.
Most recently, I used it on my Swamp Ash Tele Deluxe build.
If you have ever tried to get a mirror finish with lacquer on Swamp Ash, you know all to well that a solid base is essential to start with.
Here's what you'll need.
I always soak the fragile areas of the neck pocket in thin superglue prior to any finishing, since that area is so prone to cracking.
I didn't snap any pictures of the application process, but here's a summary:
1. Mix 50% resin / 50% hardener.
2. Wear nitrile gloves and smear the mixture all over the body. Make sure all the pores are filled.
3. With your Bondo scraper, scrape off most of what you applied, leaving just the pores filled.
4. Wipe off what you can't level with the scraper (edges, inside of horn, etc.) with a rag.
5. Let dry
It took a few applications to completely fill this body. I sanded back to wood (leaving the pores unharmed) with 320 grit between applications.
The idea is to fill the pores, and to have as thin a coat of epoxy as possible everywhere else.
The final application of Z Poxy, before spraying the base coat, was not sanded back.
This is important, the body was just wiped back with a rag on the final application.
The ENTIRE body should be coated in a very thin layer of epoxy at this point.
Here is the body after the Z Poxy treatment and three light coats of black lacquer.
As you can see, the grain pattern is completely hidden. This (lacquer) has had about 2 weeks to dry.
All we need now is a bit more buildup with clear, and this body is ready for sanding/buffing.
Here we are mocked up with the pickguard.
With a vintage/yellow tint on the all maple birdseye neck, this should be a looker.
James
5. Let dry
James
