Maybe someone can help...
In the 'manual' it says: Tighten the slotted heel-adjust nut until the fingerboard is perfectly flat
I've set up necks before, but always with strings on, for final adjustments. What's the nest way to get the neck perfectly flat in an 'un-stringed' and from the body 'detached' state ? Is there any tool I can use to see that it's perfectly flat ?
Thanks in advance !
Thanks in advance !
