Chakaranda
Hi   ccasion14:
ccasion14:
I'm a guy from Denmark now starting out to build my first DIY Strat
I've been playing guitar for more than two decades, but never seemed to find just exactly the guitar of my dreams.
I'm happy I found this forum!
I allready have benefittet a lot from searching in the forum, and hope to get more advises as the project moves on.
Here's my goal:
A Strat with a lot of sustain, crystal clear harmonics, rich and full tone but with a lot of brightness
A thin neck with JUMBO frets. = A "speedy" Neck combination (I allready have a Genuine Fender strat with that specs, but that Strat somehow doesn't have enough harmonics and sustain)
A tremolo that stays in tune even at extensive use.
Addition of Graphtech Gohst + hexpander system for the the option of (blending in) the acoustic sound + the hexpander for Guitarsynth.
I'm using medium gauge Strings (.011 to around 0.50-ish) and tune half a step down (actually I prefer to tune a whole step down but so far it has introduced a lot of intonation/adjustment problems...maybe because this tuning would require a bit longer scale neck?)
Because of the above I want the guitar itself to have a lot of brightness since that string/tuning-setup gives a bit more dark and deep sound than lighter strings in standard tuning.
I want the guitar to look nice and natural but still a simple nothing special no-name Strat, and let people discover the exeptional tone when they hear it.
Here's what I'm considering for materials, bits and pieces:
Body:
Strat Hollow Body
Hard maple with flame maple top
Contour heel
Top Routed
SSH (for the possibillity of adding a P-90 or a humbucker later)
Fender Standard Tremolo (two point) ajusted to dive only - touching body when resting for better sustain/woodtone. (will the Wilkinson tremolo could give me the same goal??)
Neck:
Modern Vintage thin (or maybe even "Wizard"? have to measure my Fender Strats neck more closely...it's VERY thin!)
Maple with Pao Ferro board
Graphtech nut (allthough I do have considerations here since I have this nut on my Fender and it seems to take a bit of the harmonics and sustain..) Well a nut can be replaced..so..
JUMBO Stainless Steel frets (i probably will get these LT 0897 from here http://www.universaljems.com/cart/fretwire.htm if my local Luthier doesn't have what i want.
Sperzel Locking Tuners.
I have been considering to just buy the Body from Warmoth and use the neck from my Strat, but i fear that if i do so I end up that The Fender Neck is not fitting precisely, + it has a RoseWood board and that doesn't exactly meet the need for a brighter acoustic response.
Finish:
Clear Laquer
White (W/B/W) or creamy Pickguard
Chrome hardware
Electronics:
GOHST+hexpander system
Worries: will the Hollow Body design be a problem when I have to carve out some extra space for the GOHST+Hexpander system?
Experiences anybody???
PU's:
I want a good allround vintage-ish clear bell-like Stratsound with the additon of some Telecaster twang, a bit on the hot side, but not as hot as the SRV sound; I'm not completely after his tone, well a bit in that direction but a bit more "Twang"
(it may look like I'm building a VERY brittle Strat, but bear in mind that the tuning/string combination pulls the sound to the dark/deep side)
I'm considering getting the PU's from Copperhead http://copperheadpickups.com/index.htm
They are handwound and they do a Stratocaster "Tele" Bridge PU (with the copperplate bottom) as well
I could go for Seymore Duncans, but the Copperhead PU's seems to do the same job but for a little less $$ + they are handwound
Since this is my first diy project, and i dont have neither the expertise nor the tools, i will have my favourite Luthier Ole Kehlet http://www.kehletguitars.com/ to do the fretting and final ajustments.
Any suggestions and comments are very welcome
best wishes to all
  ccasion14:
ccasion14:
Chakaranda
			 ccasion14:
ccasion14:I'm a guy from Denmark now starting out to build my first DIY Strat
Here's my goal:
Body:
Strat Hollow Body
Contour heel
Top Routed
Neck:
Finish:
Clear Laquer
Chrome hardware
Electronics:
PU's:
best wishes to all
 ccasion14:
ccasion14:Chakaranda
