I'm having trouble with a wiring schematic, and I just can't figure it out. I have to describe it, so bare with me.
I usually wire a volume pot like this.
left lug: earth
middle lug: output to toggle
right lug: input of the pickup
that way I can adjust the volume (duh) and when the pot is closed, there is no signal. when I use both pickups, the volume goes away when I turn down one of them. even if the other is on 10, if one is on 0, there's no sound. but also no hum, no noise, no hiss, and no 'leaked' signal. With that I mean a signal but very very faint.
I have heard that swapping the pickup-wire and the toggle wire will give me independant volumepots. so it will be like this.
left lug: earth
middle lug: input of the pickup
right lug: output to the toggle.
But now it's FAR FROM BEING INDEPENDENT!!!! this is what I get.
if I go to one pickup and I close the pot, I get a weak signal. If I turn down both volume pots to zero, there's no signal of the pickups, only huge amounts of hum that only increases when I lift my hands from the strings or anything that's connected to ground. If I use both pots they finally do work as they should.
Educate me. What am I doing wrong?
left lug: earth
left lug: earth
