Wiring help! 2 pops - 1 push/push pot - noob here
Manu101
Hi guys, lots of good info here and one of the greatest community I have found on the Web!
OK, I'm building a warmoth strat. The body and neck finishing processes are almost complete. This will be a 2 humbucker guitar with just one volume pot ( a 500K push push pot). No Switch! No Tone pot! The push push pot will act like a switch for pickup selection.
I'm sure this is one of the easiest wiring option but I'm having trouble understanding the Push push pot.
My pickups are WCRs w/4 conductors.
What I want to do is to be able to select the pickup I want to listen (no need to split the coils or to have both pops active) and have a volume...
Can someone help me with a scematic?
Thanks
Manu
Thanks you Line6man, that is what I wanted. I'm trying to get an audio path as simple as possible (with a volume control that is)
Thanks again!
Manu
You know, your path would be just as simple, with an extra option if you had a 3 position (on-on-on) mini toggle. A push-pull pot won't simplify the electronics, just the look. A mini-toggle will give you a neck+bridge option, and probably be easier to use.
