ElectricEye
Hi, I want to put a Wilkinson (Gotoh) VS1300 Tremelo into my soloist build. (I've already ordered it)
Is this going to cause issues?
*Edit* It does look like Warmoth sells the VS100N. I have added the comparison below.
The only differences are...
- VS1300 block is 1.8mm thicker than the VS100N.
- VS1300 block is shorter by 1mm than the VS100N.
I'm sure with some math one could figure out if it balances out or the VS1300 would require a little chisel work.
With the block being the only difference I think it would be safe to order the Wilkinson or Wilkinson Semi-Recessed route.
VS100N https://warmoth.com/media/skin/images/PDFs/bridges/Gotoh_Diagram.pdf
Thickness of Trem block: 11.2mm
Trem Block Length: 41mm (Shorter than the VS1300 by 1.8mm)
Trem block width: 63mm
Post: 10MM Wide, 22.55mm Tall (Same)
VS1300
Post spacing?
Thickness of Trem block: 13mm (Thicker by 1.8mm)
Trem Block Depth/Legnth: 40mm* (Shorter by 1mm)
Trem block width: 63mm (same)
Post: 10MM Wide, 22.5mm Tall (Same)
Thank you for you any input!
VS1300
Post spacing?
