In the bridge route where you screw it to the body, there should be an extra hole that goes straigh to the control route.
You should solder (or just press between the bridge and the wood) a cable from the bridge to the control routing.
Then, you shold solder the end to any ground spot below your pots.
Hope this helps.
If not, write again and when I get home from work, I will explain it with pics.
Cheers,
mo
