Jerryatrick
Installed a new neck HB. A 4-wire single coil-sized dual blade puperoo.
Position 5 sounds great. But had a substantial volume drop in position 4 (neck HB plus middle SC).
So I swapped the hot and the ground leads of the neck pup.
Position 5 sounds great still. Position 4 sounds a tad different but still has very similar substantial volume drop.
Does switching the hot and ground leads mean I have to do something different with the bare ground wire too?
Should I try switching the hot and ground leads back to original spec and swap the series 1 and series 2 finish leads instead?
