I have decided to setup my SD P90 stack with a 5 position rotary switch. The positions will be:
1: Both coils parallel
2: Coil tapped
3: ?
4: Power Boost
5: Both coils series
The power boost will be done as described here: http://www.seymourduncan.com/images/products/electric/specialized/501025-105.pdf
At the bottom of the page.
My question is, what should I put in position 3? Stewmac only has 5 and 6 position rotaries, and I have no interest what so ever in going to a blade switch. I considered going for a out of phase option on position 3, but I don't think it would be worth it. The coils sit on top of each other in the stack, so chances are it would cancel out almost the entire sound. I was wandering if someone could suggest some sort of tone choke/notch filter/etc that would be a cool unique sound that I could put in that middle position.
2: Coil tapped
3: ?
4: Power Boost
