ChrisMC
So, I have a top mount Floyd setup, with an R3 nut, on my Soloist build. I loooove this guitar and haven’t been able to stop playing it. Everything was PERFECT, and all I did today was swap out the R3 for a Kahler nut, at the suggestion of a forum member, to get rid of the string retainer bar (I hate that thing, but it’s a necessity with a Floyd nut.).
So, the Kahler lines up well, it mounted just fine, my string to string spacing is where it should be, the E strings are properly spaced from the fretboard edges, and when I play fretted runs of notes, it seems to be in tune with itself, but the entire fretboard is basically a 1/2 step off with intonation. ??!!!???! There is NO 12th fret harmonic, because it’s so far off; there’s a 13th fret harmonic.
I’m stumped. The edge of the nut is (almost) right up against the edge of the fretboard, where it should be. I did notice that there’s a hairline gap between nut and fretboard, but that shouldn’t be a 1/2 step worth!
The only other thing is that the action is too low because the nut shelf is of course cut for a Floyd R3, so I need to play with some shims, but I don’t think raising the action a couple of 64ths is going to resolve a 1/2 step of intonation.
What is going on here?!?!?!?! Any ideas? Anything I can try?
I can very easily revert back to the R3 and string retainer bar, no problem, very simple, but I like this Kahler nut and would love to use it.
It’s a Kahler 5532 nut with String Director. Thanks for any input.
