Warmoth Jaguar & Jazz Master Bodies
AdvenJack
Are these two bodies shaped and sized identically? ( I believe so.)
I mean if you layed one on top of the other would you see any difference?
Thank you!
Jack
One definite difference you need to be aware of, these bodies are not interchangeable. The shapes are similar but they are not identical and so you would see a difference.
A Jazzmaster is made for a 25.5 in scale length, while the Jaguar has a 24 in scale length. The necks for one will not intonate or work on the other.
Upvote 0
I believe these images originated from the Offset Guitars forum. Both are examples of Fender bodies. The first has the bodies aligned, and the second has the neck pocket aligned. Red is the Jag, blue the Jazzmaster. I'm not sure if Warmoth bodies differ slightly from Fenders.
Upvote 0
