fdesalvo
Long time, gang! Finally getting some breathing room.
So, I’ve come to a realization about my preferences. I like a 1-5/8” but width, but ONLY if the string spacing at the bridge is not narrow spaced. As it turns out, the 510 warmoth sells is actually the NS510T, designating the narrow spacing of 52.xx mm.
I never knew I had a preference until I wandered into this configuration, finding it cramped all the way up the neck. The standard 510 sports a 54mm string spread, but the block is a bit wider, pushing the trem barrel outwards, as well. While I’m equipped to adjust the current bridge route, I’d rather have a drop-in solution given my limited free time.
Can anyone identify the dimension of the standard Warmoth Gotoh route and maybe shed some light on this scenario?
All the best - been too long!
f
f
