Walnut
XxDBENCxX
Does anyone have a picture of a guitar with a WALNUT and OIL finish?  I am ready to start my first guitar but I cant seem to find a picture to make sure that this is what I want. Thanks guys!
jackthehack
Not sure which type of "oil finish" you mean; the Strat in the link below is figured walnut with a WATCO Danish Oil finish; but that is NOT a "hard" oil finish like tung oil or Tru-oil.
http://www.unofficialwarmoth.com/index.php?topic=234.0
willyk
here ya go... danish oil and carnauba wax. No grain fill, just wet sanded the oil into the wood with wet/dry 400
tfarny
Here's a couple quickies of my walnut thinline in progress. Minwax dark walnut stain (2 coats), this is after the 2nd coat of tung oil, applied today. No filling or sanding.
Ted
Love that finish!
XxDBENCxX
You guys are great! Thanks for the help! How does walnut sound compared to other woods? I'm guessing a darker tone.
willyk
I've built 3 walnut instruments and they all sound different. The jazzmaster has a maple/kingwood neck and is a great sustaining mid-bright guitar. I have a tele with a padauk top and padauk/ebony neck which is rather warmer. The 3rd is a jazz bass "sister" to the jazzmaster. That one has flatwound strings and sounds real woody and smooth.
I guess all you can deduce from this is that it depends on other factors how the guitar eventually sounds.
I love walnut, it's a beautiful wood to work with and quite easy to achieve a great finish. It's musical and will deliver a great sound (as previously explained) My only issue with it is the weight. The tele is fine, the jazzmaster has a bigger body so it's getting up there and the jazz bass with all the extra steel in the bass neck makes it a 12lb+ proposition.
tfarny
No idea how this will sound, other than what I've read. As for finishing, it sure as heck is easier to work with than swamp ash! I was going to grain fill this walnut body but on close inspection I decided it just wasn't necessary. Weighs almost 4 lbs whichis heavy for a thinline, I gather.
