I'm placing the order tomorrow. here's a mockup pic thanks to DangerousR6, and below it are the specs. I found out that this will be the first production Jaguar Bass body that Warmoth has ever made and/or sold to the public! ^_^ SUPER excited to get this put together and plugged in! it's gonna ROCK! also, a HUGE thanks goes out to Eric Wylie! he was a freaking saint through all this. I changed my mind dozens of times over super small details to huge details all the way up until payment, and he was SUPER polite and friendly all the way through. he also helped me get the Jag body. without him, I would not have been able to get this ordered. so, BIG thanks go to him, a class act.
...this should be fun.
body:
solid body
wood - swamp ash
orientation - right handed
control cavity - rear route
pickup routes - Dimarzio Will Power Model One in the mudbucker position, Dimarzio Will Power p pickup in the standard p position, and Dimarzio X2N-7 humbucker in the bridge position
f holes - none
controls - mini toggle 3 way switch for tone cut/volume pot for Model 1/concentric volume pot for P and X2N-7/tone pot for P and X2N-7/ 3 way toggle switch (series/parallel/single coil) for coil tap for X2N-7
input jack route - two outputs secured to this output plate - http://www.guitarpartsresource.com/images/large/SMJP-B.jpg. it measures 2-3/8" x 1"
bridge - Badass III string thru body
mounting holes - standard 4 bolt pattern
contours - tummy cut and forearm contour
binding - none
stud install - n/a
battery box route - none
finish - sunset orange
neck:
p bass style
wood - canary for neck and fingerboard
nut width - 1 11/16"
back contour - standard
fingerboard length - 21
binding - none
fret size - SS6115
tuner hole - hipshot ult lite (14mm) with hipshot D-Tuner
inlay - black face dots
string nut - Graph Tech Black TUSQ XL
finish - n/a
electronics/hardware:
Mudbucker position - Dimarzio DP145 Will Power Model One
middle position - Dimarzio DP146 Will Power Model P
bridge position - Dimarzio X2N-7
body:
solid body
wood - swamp ash
f holes - none
binding - none
stud install - n/a
neck:
p bass style
binding - none
fret size - SS6115
finish - n/a
