When I hit certain notes (D, F) something in my head vibrates. I suppose it must be the tubes... it's a little like the noise when you shake a busted light bulb. I don't think any of the tubes are bad, it sounds like it always did and all the tubes heat up... Could a tube be loose or something? I'm afraid of fiddling with it
Should I just check if all the tubes are in all the way?
