Shandrazar
I have a PRS Soapbar II SE (2 P-90s, 1 Vol, 1 Tone) that I am considering upgrading with Lollar pickups. I discovered that the Lollars and virtually all P-90 replacements use a shielded coaxial wire where the shield wire is bare. My stock pickups have normal wires connecting them to the controls, so I know it isn't inherent in the P-90 design. Is there a technical reason for this, or is it simply a matter of everyone doing it the way Gibson originally did it?
The reason why this matters to me is that if I am going to rewire, I might as well try to add some extra flexibility into the design. I was thinking of adding a push-pull for series/parallel switching. Has anyone done this with P-90s? If so, how did it work? I also haven't ruled out a push-pull phase switch, although I suspect it won't be worth the effort. Has anyone tried that?
Shielded wiring would make this all more complicated. The shielding would be too clumsy to be soldered to a lug directly. I would have to solder a normal wire to the shielding for ease of use. I would also have to insulate the shielding wire with shrink tube or electrical tape all the way back to the pickup to avoid accidental shorting.
