SmooveOperator
I am doing up my first project which is a swamp ash strat body with a quilt top maple laminate. I am getting a finished neck from warmoth, as I think the body is going to be enough of a project for a first timer.
I am going to use water based dye on the body but I have a few questions in particular on the process of the clear coat.
I know that the water based dye will raise the grain so I plan on taking that down before the clear coat with some 400 grit sand paper.
I plan on using ColorTone Aerosol Guitar Lacquer from stewmac. (Is this a solid product?)
My questions are:
1: Do I need to apply a sealer before I put on Lacquer?
2: If so, can you recommend one?
3: Should I sand (wet or dry?) between coats of Lacquer?
4: How many coats of Lacquer should I apply?
5: Should I buy a buffing compound and polishing pad, or is that not really necessary?
My goal here is to have a really nice, clear, durable finish to this guitar. I am trying to plan this out as best as possible so I don't have to post here asking how to fix a mistake.
Thanks in advance
My questions are:
Thanks in advance
