Evilfanclub
so I painted the body and neck this weekend. I had to do some control cavity routing to accept the sustainiac board and pots. wet sanded and buffed the body, not perfect yet. I might have rushed the primer a bit. 2 heavy coats of primer/sealer. sanded the first with 320 grit. left the second alone. 4 coats of base. (DuPont chromebase fiesta red), then 6 coats of clear. it orange peeled a bit but I wet sanded with 1000 and then 1500 grit, then buffed with 3m finess. she shines. a lot. but I think I should have went with another coat of primer and a least one more base. the reason I say that is up real close I can still see the grain. or I should have fine sanded the body down to 1000 grit. hind sight. metal is easy to paint. don't have a lot of experience with fine wood. need to finish the neck this week. I sanded out the little bump that comes on the slapshot head stock. also if anyone knows... can I shield the control cavity wile running a sustainic? their sight says no shielding in the pickup cavities but nothing on the control cavities.
