Volitions Advocate said:Technically Orpheo. If warmoth builds their parts for a 25.5 scale then really the pickups even though its further away from the bridge if you're measuring,, techincally its in the same spot as far as the string harmonics are concerned. Because when you're talking about changing scale lengths its not the exact dimensions that are important because its all relative to the scale length. I'm not trying to call anybody dumb or anything, but I think complaining about the pickup being in a "different place" would be like complaining that the frets have wider spaces in them on a longer scale neck.
The pickup itself. if you used a tape measure would indeed be in a different spot as far as the measurements are concerned, but for the longer scale.. that little sweet spot where the p/u is supposed to go has moved a little further away from the bridge.. so the p/u should be moved to that spot.
or am I missing the point?
GoDrex said:Yeah I just measured the distance on my Parker that is 25.5 - and they're the same. So I guess it's the wood and pickup that make my guitar less bright. Or would a 24.75 neck make some difference? I don't know. I think my explorer will be 25.5 instead of 24.75 just to be sure.
GoDrex said:I also have a little more trouble with pinch harmonics. They're not impossible but not as easy as on my other guitars. I definitely feel like there isn't as much treble as there should be, but I like the sound anyway. Kind of have to learn to live with it after spending $1800 on it.
Orpheo said:agreed.
GoDrex said:I can do pinch harmonics ok on my LP - but I've just noticed it's a little different that say my Parker or my star (made by warmoth) which are 25.5 scale. I thought maybe it was my pickup - an SD Custom - but it seems like it should be OK for that. I can do them but it doesn't seem as easy. I've felt since I got my guitar that it's perfect for classic rock and blues more than anything. It doesn't seem to like really high gain as much. But that could be for any number of reasons.
Orpheo said:the sd custom is great for that. I think i'm gonna use just 25.5 inch necks for new builds. Warmoth makes the bodies for 25.5 inch, as they've always claimed. we just didnt read properly, I guess. by using a fender-scale, they can have a 24.75'' conversion-neck for these guitars, but at the cost that the bridgepickup is NOT at the sweet spot. using a 25.5 inch will solve it. Using squeeling pickups (with a conversion neck) and a very, VERY good pinching technique, shóuld give us the pinch harmonics we're used to on normal les pauls.
@Nonsensetele: I think that one is also a 25.5'' body. use a 25.5'' neck, and you're sorted. Warmoth didnt do anything wrong. we just assumed things, and didnt read properly.
NonsenseTele said:Orpheo said:the sd custom is great for that. I think i'm gonna use just 25.5 inch necks for new builds. Warmoth makes the bodies for 25.5 inch, as they've always claimed. we just didnt read properly, I guess. by using a fender-scale, they can have a 24.75'' conversion-neck for these guitars, but at the cost that the bridgepickup is NOT at the sweet spot. using a 25.5 inch will solve it. Using squeeling pickups (with a conversion neck) and a very, VERY good pinching technique, shóuld give us the pinch harmonics we're used to on normal les pauls.
I knew it was made for 25,5", but I didn't think it would change the tone... I'm not going for 25,5", even more that the fretboard is already cut in 24,75"... I'm searching for 24,75" sound...
Orpheo said:you must have a good/better technique, thats it
stubhead said:Complaining about Warmoth's dimensions/quality/execution/"tone" because you don't want to practice enough to be a good guitarist is pretty nutso, huh? :guitaristgif:
