truss rod adjustment on first time neck set up
WindsurfMaui
So my first modern style neck is scheduled to arrive tomorrow. When setting up the neck for the first time is there a pre attachment adjustment that I should make to the truss rod?  One reason I prefer the vintage/modern style is that the truss rod adjustment is at the headstock so it is easy to tweak. I understand the current modern necks have a side adjustment for minor adjustments. But is there a pre set up adjustment that I should make that gets the neck in the zone so the side access can be used for minor adjustment? 1/4 turn, 1/2 turn? I'm just trying to avoid having to disassemble the neck from the body a couple of times until I get the neck close to how I like it.
I would have stayed with the vintage/modern style necks except I wanted a roasted maple shaft with an ebony fretboard so I ordered the modern build. Generally I like the neck to be as straight as possible so do I have to make any adjustments first or just attach it to the body?
http://www.warmoth.com/Guitar/Necks/SideAdjust.aspx#Adjustments
