I am building my first Warmoth Strat (of my dreams). I am going to Tru-Oil the maple neck, the Pau Ferro fretboard will be masked with 3m Scotchblue Painter's Tape Advanced Delicate Surface.
My question is: Will I get Tru-Oil build up at the edge of the tape and if so should I remove the tape between coats and to aid in any build while I am wire wooling? I Also worry if the mask is not perfect I will get Tru-Oil seeping into the edge of the Pau Ferro making it scrappy looking on the fretboard side.
I don't intend to use any dyes or any other form of sealer just the true oil. As far as I can tell for trawling through the many great threads this is more than enough.
Martin
hmmm finding it difficult to source that particular tape in the U.K.. Then again I sourced my guitar parts from Warmoth as I could not find quite what I wanted in the UK. Seems the U.S. is the place to be
Martin
