TBurst Std
Needing to put in bushings for a TOM styled bridge and tailpiece. (Also needing to install string ground).
No press available.
Figure freeze the bushings for a day. Lube them up with wax as well as the holes, then drive them in gently with a hammer and block of wood.
Anything else to think of?
Also, the only wire I have on hand is 14 gauge multistrand. Is that to big to stuff into the hole then drive the bushing into? Should I go find some 22 gauge, or 18 gauge?
No press available.
