Tobacco sunburst strat
Schlieren said:
back2thefutre said:
Did you put the Schaller Sure Claw in? If so do you know where I could get one? I've looked everywhere ???
http://www.thomann.de/gb/schaller_377_sureclaw.htm
You'll have to pay VAT and likely something like a $40 fee for your bank to wire funds to their bank, but it'll get to you
Thomann.de is one of the only places to get most Schaller stuff, at least with any reliability
I got my Schaller stuff from guitarsupplies.nl , they also are really great
Hi, I'm rather curious, what is the Schaller 'Sureclaw' how is it mounted and whats it supposed to do?
Thanks!
ORC
It is a different anchor point for the body end of the trem screws.  It also allows adjustment for spring tension by turning one adjustment with an Allen wrench instead of screwing in (or out) 2 wood screws with a Phillips head screwdriver at an uncomfortable angle from the body.  It also allows this without removal of the coverplate.  It occupies the same space as the tremol-no, so can't be used in conjunction.
As said above, the shure claw is screwed on to the bottom of the trem cavity and adjusted with an allen wrench. It makes it much easier to adjust the string tension. It might be my imagination but it seems to ad alot of sustain to the guitar.
