pabloman said:To me copper tape looks amateurish. Not sure why. If you do shield it go with the paint. I guess maybe it looks cleaner to me. I don't know.
cmalidore said:I was never able to find a good reason not to do it. ALTHOUGH, that stuff is sharp as all hell. Not a fan of that part of it.
DesmoDog said:cmalidore said:I was never able to find a good reason not to do it. ALTHOUGH, that stuff is sharp as all hell. Not a fan of that part of it.
I used teh Stew-mac kit too. A little later I discovered a bunch of small cuts on my fingers from the edges. Never felt it cutting while I was installing it.. but it sure as hell cut me up.
That said, my Strat has zero noise issues while a different guitar I has major sound issues. (But I didn' twire that one so who knows what is goign on with it). Anecdotal to be sure, but I see no reason NOT to shield either.
I didn't cut myself but got a couple nice burns from my superior soldering skills.
Klark said:http://www.manchesterguitartech.co.uk/electrics.html
I've seen guys that just do the cavity, and forget that the bottom of the pickguard needs to be done as well. Duh!
Super Turbo Deluxe Custom said:If shielding a humbucking guitar with hum mounted to metal plate (most are), with leads traveling through shielded cable (most are), with grounds soldered to chassis of pots (most are), the only unprotected areas are the small pickup hot leads were it emerges from the sheilded cable and terminates on the pot and the capacitor on the tone pot, which is grounded on one end. So basically, shielding only protects the small area of un-shielded pickup lead and humbucker coils if uncovered.
On a single coil, no amount of sheilding will ever make them not hum. It may keep them from humming more than normal, such as when near a Neon sign in a bar.
