Last weekend I installed the Onyx Forge zinc inserts in my '87 Fender American Standard Stratocaster neck. The existing screw holes in that neck were pretty beat up from having been removed and re-torqued several times over the years so I figured it was a good candidate for neck inserts, more so than a new neck from Warmoth.
The Fender neck is maple, easy to drill and I used the 15/64 drill bit Onyx Forge sells with the kits (I already have a decent bit set but wanted a fresh, sharp bit and it was only a couple bucks extra). I used a cheap Harbor Freight drill press and verified that the drill was 90 degrees to the work platform first. I supported the neck on a piece of soft scrap wood to keep from damaging the frets. I clamped the neck in the exact center to make sure it was completely level with the work platform of the press. This is important; I fortunately discovered before drilling that clamping even a little off to one side will rock the neck to one side on the curved neck radius which would result in a hole drilled out of line with the existing screw holes. A better way would have been to clamp it on the sides with square blocks. The drilling itself was a total non-issue, very easy. Going VERY slow and making sure I was 100% lined up before taking the plunge with the bit. I did have an extra insert in my kit and practiced on a scrap of Pine. My cheap drill press has a tiny bit of side to side movement in the drill head which actually turned out to be a good thing – the drill followed the existing screw holes perfectly. I measured depth before drilling and marked the bit with a piece of tape. Obviously, a pretty important detail; you definitely want to get that one right.
Installing the inserts – likewise, non-issue. I used wax on the zinc threads and screwed them in by hand with an Allen wrench. The inserts lined up and followed the drilled holes perfectly. I screwed them in just under flush with the wood on the neck heel. The wood did dimple up slightly and I sanded this down in a few seconds with 300 grit paper.
Re-installing the neck – no problems, the screws that came with the kit lined up fine. Got the neck TIGHT, within reason of course, but torqued down way tighter than I would have been comfortable with using just the wood screws. Enough that I could just barely see the plastic pad I added under the neck plate start squishing out.
Overall, real happy with it and glad I went to the effort. I bought the Onyx Forge kit because it came with black screws – and also knowing I was getting something that had been used many times before with no issues. Actually, I bought two sets – one for my Strat and one for my upcoming Warmoth Tele build. I am still undecided about using the inserts on the Tele neck since it is Mahogany. Probably should use a tap first, which is no problem but I need to make sure I get the right one which I think is 5/16-18 (?). Need to check into this…
Hope this info is helpful to anybody thinking about installing inserts.
