Steve_Karl
I've just got around to starting the wiring of my Korina Strat project and the thick panel jack wouldn't mount.
There weren't any (zero nada) threads exposed on the inside when it was pushed through the hole and that's not even trying to use the rubber washer that's supposed to go on the outside.
Here's my sloppy but functional fix to also be able to use at least the metal washer on the inside and also be able to thread the nut onto it.
I'll not be using the rubber washer on the outside. I'd have had to go an other 1/8" inch farther down to allow that to fit also.
I love my dremel tool.
Maybe it was a fluke ... that mine didn't get routed properly. Hopefully that's the case and others aren't running into this problem.
