Sid Nitzerglobin
Well the attachment didn't do too well w/ the whole perpendicular thing for the remaining string through and ferrule holes but at least they weren't so screwed as to be non-functional, just not all that pretty. Might be an excuse to try one of these:
http://www.delisleguitar.com/shop/de-lisle-string-ferrule-block-brass/
The additional mass towards the end of the guitar would probably be a positive for overall balance as well. It's not diving, but the combo of the feather weight body and kinda heavy tuners makes it seem like it wants to rest completely parallel to the ground. I've held off on drilling my strap button holes until I decide if I want to give a ferrule block a try.
Got it strung up and did the bridge cut in the pickguard on Friday night and set it up pretty well and finished up making the neck pickup hole fit the claw on Saturday. Intonation seems very good and aside from maybe needing a bit of a fret dress above the 16th fret it's playing great. Has a really nice bouncy/snappy kind of feel to it and it really pops acoustically.
The press attachment was very useful for expanding the bridge pickup cavity yesterday. I got most of the material removal done with a couple of Forstner bits and shaped and cleaned it up somewhat w/ the Dremel and a sanding wheel:
It took some time, but was actually kinda fun.
In between working on assembly and setup I finally got started on some finish samples Saturday and Sunday (which unfortunately I neglected to take any pictures of), and I think I've got a couple options for the tint that I'll be happy with. Surprisingly I seem to be having the best results brushing on the dye rather than rubbing or spraying it on. It seems like it really, really needs to be super flooded w/ the dye to get close to the saturation that I'm looking for. Currently I think I'll be using a couple passes of a 1 oz alcohol, 42 drops of green, 13 drops of lemon yellow, 7 drops of black Transtint solution on the raw wood followed by 2 or 3 coats of shellac sanding sealer for the base staining. I wound up picking up a rattle can of Behlen Starcast Amber toner and I'm toying w/ the idea of incorporating a couple coats of this stuff over the shellac before the Stringed instrument lacquer topcoats. Gonna spray a sample like this tonight and see what I think.
I went ahead and got started on the wiring last night and am hoping to have it all done tonight:
Here's where I left it last night:
