B
back2thefutre
I say go ash for something different :icon_thumright:
and a floyd roselidesnowi said:One piece Hollow Alder back with a Swampash top with a one piece Q sawn big fat wide Maple neck :icon_thumright:
No this http://www.tisonix.com/shopping/main/index.php?main_page=product_info&cPath=66_75&products_id=202back2thefutre said:and a floyd roselidesnowi said:One piece Hollow Alder back with a Swampash top with a one piece Q sawn big fat wide Maple neck :icon_thumright:
NovasScootYa said:If you are going apply the finish yourself it's Alder. Pourous Ash requires more prep work prior to finishing. If you do not finish it yourself again it's Alder. You did not specify which Ash, some Swamp Ash is way too light while some Northern Ash maybe too heavy. Generally Alder is somewhere in the middle and a safe choice.
NLD09 said:btw... Why have we all been capitalizing the names of the woods? Is it because they're names, or is there a different reason?
Yes I too would rather look at Ash; almost slipped another s in there and had a bureaucratic snafu.NLD09 said:NovasScootYa said:If you are going apply the finish yourself it's Alder. Pourous Ash requires more prep work prior to finishing. If you do not finish it yourself again it's Alder. You did not specify which Ash, some Swamp Ash is way too light while some Northern Ash maybe too heavy. Generally Alder is somewhere in the middle and a safe choice.
I sort of agree. If you're going with a solid finish go Alder, but if you're going with a transparent finish, go Ash.
Wasn't the Penguin from Our Lady of the Blessed ShroudOrphanage was it..... :dontknow:NovasScootYa said:Yes I too would rather look at Ash; almost slipped another s in there and had a bureaucratic snafu.NLD09 said:NovasScootYa said:If you are going apply the finish yourself it's Alder. Pourous Ash requires more prep work prior to finishing. If you do not finish it yourself again it's Alder. You did not specify which Ash, some Swamp Ash is way too light while some Northern Ash maybe too heavy. Generally Alder is somewhere in the middle and a safe choice.
I use caps for Ash and Alder because they’re proper nouns and I’m a right wing tree hugger showing my respects. Actually, it’s attributed to a very large nun who long ago taught me reading, writing and arithmetic.
stubhead said:At close to 40 years of Fendering, what I believe is that the overall weight of the piece is probably more important than that particular wood choice. In fact, in a blindfold test, I really doubt the most conceited "expert" could hear the diff between a 4lb. 2oz. slab of Swamp Ash, Alder, Mahogany, Walnut, Fruitwood or any other thing. I suppose a real expert might be able to hear the diff between a 4lb. 2oz. board and a 3lb. 8oz. board, if all else was equal, he'd had his (ear)wax done and Venus was in the aspect of Mars*. And he had his lucky socks on....
Neck wood is about 77.25% of it, including size - and Big Fat & Maple wins, always. Pickups and Wiring are another 162%.....
I love the look of an nicely amber'd slab of Swamp Ash, but if you're going solid, Alder is easier to finish.
* http://www.cafeastrology.com/natal/venusmarsaspects.html
