Tele Measure...
greenmean
Hi,
I need the thickness of a Warmoth-finished Tele Body & the distance between Body Edge (where the Endpin is) and Bridge (the point where the strings break over the saddles).
When possible in mm.
Anybody got them?
I need them for a custom-order on a Tailpiece.
Thanks in advance
If you're the patient sort I can get them.  You may have to do the metric conversion yourself (my dial calipers are in inches).
The Body + Neck I order right now will take 7-8 weeks. So call me patient  :)
I will do the metric conversion. I found some calculators in the web.
Thanks in advance!
Back again.
Measurement from tail piece to bridge saddle.  I took this to the "g" string.  5 5/16 "
Body width at tail piece:  1.77"  (using dial calipers)
