TBurst Std
OK work and project load is finally coming down. As you may know I have a VIP build that is 3 years delayed. What you don't know is the Tele build that is 7 years delayed LOL.
So anyways I am thinking through this and have a Q.
It's routed SC neck and bridge. Already have a Zhang bridge pup for it. It's the 2nd Paul Bunyan ever built. Except with a twist. It's wound almost to P90 specs with a tap to normal Tele spec.
So I am thinking a Zhang neck pup. Now I would like to have B, BN parallel, BN series and neck. And 3 of those 4 with the option of tapped or not on the bridge.
Thinking the best way to do this is a 4 way Tele with a micro switch for the tap.
Your thoughts recommendations. Maybe have the tap on the 4 way and have the micro control parallel vs series. Doable?
