Switchcraft Switch Dimensions.
Jeremiah
I just ordered a Switchcraft 'short frame' toggle switch from WD Music in the UK, and I'm wondering if they may have sent me a long one instead. The one I got is clearly too long to fit in a top-routed body, and in fact is only barely shorter than the full body thickness of a Strat-type guitar.
However, I am having difficulty tracking down what the dimensions of the 'short' switch should be; the one I have is just over 1.5 inches from the bottom of the switch to the top of the frame where the screw thread starts. Does anyone who has used these switches in the past know if this is really a short one, and the long ones are even longer? If so, I probably need an SG-style right angle switch (or a different brand) to fit on a pickguard in a top-routed body.
Have you considered the "right angled" toggle switch?
http://images.google.com/images?hl=en&q=gibson%20angles%20toggle%20switch&um=1&ie=UTF-8&sa=N&tab=wi
I emailed WD Music and they got back to me quickly - it looks like they sent me the long switch by mistake so I should be able to get it replaced.
For anyone else who's thinking of buying these switches and is curious about the dimensions: the long one is 54mm total length without the switch tip, and the short one is 39mm.
