Great Ape said:
			You are gonna LOVE that Swart!! It's been my #1 amp for years, and every single time I play someone (usually another guitarist) remarks on the tone. It's a real gem.
Yep, just plug straight in, no pedals needed.  Those tubes!  He's got a
new one out, the "MOD 84" which is based on EL-84 tubes, and I
almost got it instead but I wasn't sure I'd like it as much as this one.  Here are some pictures of it:
And, the Alligator look:
It was a close call.
I'm glad I got the STR, but check out these specs on that MOD 84:
    All Tube circuit ~15w twin EL-84 High Class A Bias AB
    Swart's first EL-84 amp ~ Push-Pull EL-84 Power!
    Cathode "AUTO" Bias (no need to bias)
    12AX7(2) - 12DW7(1)- EL-84(2) - GZ34 or 5Y3(1)
    Tube Rectification ~ GZ-34/5Y3 for compression/earlier breakup
    Top Mounted Controls for Front/Back Access
    3-Way Interactive EQ Switch
    Tube Reverb via 12DW7 with Spring Tank
    Tube Tremolo with Custom Speed Sweep/Depth
    Hi/Lo Inputs for better PU Output matching
    Hand wired point to point ~ Made in USA
    Standby Switch ~ Warm-up up extends tube life
    Carbon Comp Resistors for BEST TONE
    Teflon covered High Purity Copper Wire
    Mallory, Sprague & JJ Caps, selected for Application
    8ohm Custom Wired Heavy Duty Output Transformer
    Dedicated 2 button foot switch
    Extra Large Rubber Feet for Vibration/Protection
    Solid, finger-jointed Pine Cabinet ~ Vintage Inspired Coverings
    1x12 & 2x10 cab ~ Creamback/Gold/Blue/Options Available
    Dimensions: 26 x 15.5 x 10.5   39lbs
Can't wait for the UPS MAN TO GET HERE!!
