Strat pickguard SD JB question.
TwiztidThorn
Hi,
      I'm sorry if this has been asked before, but I tried to search and got an error message.
I want to order a pickguard for my left handed strat, but had a question in regard to the bridge pickup size option.  I plan to install a Seymour Duncan JB Trembucker, but could not find an option that matched the dimensions  provided by SD on their page.  If it matters I won't be using a cover or ring on the Trembucker.  I hope someone can point me in the right direction.
warmoth's fender humbucker route should be perfect for the JB. i have a JB in my telecaster deluxe and it works fine in the pickguard. actually the only humbuckers that shouldn't fit in that pickguard would be gibsons i believe.
Thanks for the reply.  I hope it wasn't too much of a noob question.  Wanted to make sure it would all fit .  Thanks again.
no way, man. i emailed warmoth the exact same question before i started my build. i was pretty sure i knew which was which before i asked, but it'd be way worse to not ask and have a problem
