Hello,
I'm looking for opinions on the attached wiring schematic. Could you point out possible flaws?
I have a coil splitting option which selects the two outer coils. When the Phase reversing toggle switch is pushed with the coil splitting it will switch to the two inner coils.
In 'Strat Mode' the 5-way selector switch acts like a standard strat, with coil splitting and phase reversing options like above.
In 'Les Paul Mode' Only the hum buckers are used. I have two seperate volumes for Neck and Bridge as in a Les Paul.
The volumes are wired in a decoupled configuration so that if one is turned all the way down, it does not ground the output and kill the other one too. Will this give more treble cut as the pot is decreased?
Any observations would be apreciated.
