Finally some progress on this one - had relatives visiting and lots of work so I stuck this under the bed for a while after applying mcfadden's grain filler. Today I took it out and started sanding out the grain filler - the mcFadden's sure is nicer to work with than the stew mac water based, maybe because I let it set for several weeks. Only one filling needed, for sure - it's in there like a rock. I read the directions wrong and diluted it with lacquer thinner instead of naphtha but it worked a treat in the end. I think the matching headstock is pretty good - better if it were flamed but oh well. Pups are bill lawrence, I have a covered bl neck pup I'll probably use instead of this one.
All the parts have arrived so I did a test fit. Still need to finish sanding out the filler on the sides and touch up the 'clean line', as well as the F hole, then satin poly or tru oil, haven't decided, over it all. It's going to be a good one, now that I really need bass rig instead of one more electric guitar!
