Ace Flibble
Right, I've had a build in mind for a while now and I'm finally just about getting the funds to do it. Before I pull the trigger on it though, I want to double-check my intentions for the finish.
Being very lazy and also not someone who cares about showing off pretty high-grade grain or whatever, I was thinking a poplar body (solid body Tele) and then using spray cans for well, pretty much everything. I also want to marker pen on a design. A friend of mine works in a Games Workshop and can use his employee discount there to get 400ml cans of white spray paint and satin polyurethane spray cans for me dirt cheap. So I'm thinking fill the grain, spray on a couple of cans of white, scribble on my design, then spray on a few layers of poly and be done.
For what it's worth, this guitar really doesn't need to look top-quality, in fact the more bashed in, rough and scrappy it looks the better, hence why I'm happy to just spray it myself.
The things I'm unsure on are basically how much spray I'll need (especially the poly) or if there's anything particularly disasterious I should be aware of when doing something like this. For example, could one 400ml can of poly cover a body sufficiently or should I be buying hundreds (I want a moderately thick finish on this so it can take a good bashing)? If there really any need to fill the grain of poplar with such a basic finish (and given poplar is apparently quite closed-grained)?
Everything I look up talks about high-quality finishes and sanding back layer after layer of wipe-on poly or nitro and I've yet to find anything explaining a simple finish like this. So yeah, any help is very much appreciated.
