CreativeName
Hi everybody
This is my first post on this forum because I'm totally new at all of this. I'm just gonna throw out a disclaimer right here, a lot of my questions may be unbelievably stupid to you, but I've never done any of this before, I've never taken a guitar apart before or anything like that. I currently only have one guitar, my Strat, and I've had it for a year. So be nice, ok?
So here's what's happening. I want to build a double neck guitar. Just like most other double necks, the top neck is going to be a 12 string, and the bottom one is a 6 string. I'm using the Double-Strat body. I've gone and picked out most of the parts from Warmoth, but I still have a lot of problems. Here's my list:
If anybody answers these questions, I will owe them my eternal graditude.
Thanks in advance
Brian
- Does the 12-string need special pickups that are different than those I'm using for the 6 string? Or can I just buy 2 sets and use them for both necks?
- For my six string, which of these two bridges (found at http://www.warmoth.com/guitar/options/options_guitar_bridge_routing.cfm) are better? The "Vintage Style Strat" or the "Narrow Spaced Strat"?
- The 12 string only comes in one nut-width - 1 3/4 inches. Should I make the 6 string the same width? Will this affect the way the necks fit into my guitar?
- In the online order form for a neck (http://www.warmoth.com/customerservice/orderforms/order42.asp) option #16 asks about the nut. If I put "None", will I just get a standard nut? Or, for some reason that makes no sense to me, would I not get a nut at all?
- Does that bridge that works for the 12 string, or one of the bridges I selected for the 6 string add any additional cost to my order? Or are the costs of bridges included in the body cost?
- There is a box next to "top routing or rear routing" in this order form (http://www.warmoth.com/customerservice/orderforms/order5.htm). Does top routing add more money to my order? I don't want rear routing.
- In that same order form, what do options 8 (pot hole locations) and 9 (switch slot) mean? What do I write in those?
- ONE LAST QUESTION!! In the pickguard order form (http://www.warmoth.com/customerservice/orderforms/order6.htm), what do options 6 and 7 mean? What do I write in them?
Thanks in advance
Brian
