Should tone controls remove ALL the tone?
DarkPenguin
I've just put some alpha pots in my guitar as tone controls.  I expect that when I turn the volume all the way down that it should mute the guitar.  I wouldn't expect that from the tone controls.  Is this how they work or did I miswire something?
You've mis-wired something, or perhaps your capacitor is much too large.
Yeah, you've just added more volume controls.
The typical tone pot uses a capacitor to "scrape off" tones above a certain frequency (determined by value in microFarads). If you're scraping off 100%, then you've missed the cap entirely.
The voltages in a guitar are not going to fry anything.
If the cap is bad it probably came that way.
What are the caps values?  (Published and measured)
I was thinking fried with a soldering iron.  Baked more than fried.
0.22, I believe.  I'm sure I have a meter of some sort around the house.  Haven't found it.
Yep, the heat of a soldering iron can fry pretty much anything, especially if you heat the thing more than a few seconds.
That's your problem. 0.22(uF, I'm assuming) is an order of magnitude too capacitive for the average signal impedance in a passive instrument, and even a bit high for lower impedance active circuits. The result is a very low frequency cutoff point, basically allowing the pot to vary output impedance over all frequencies.
For the love of...  I don't want to admit this but what I did was wire the capacitor into the wrong spot.  Then when I bent it down to tidy it I completely masked how it was wired.  In other words it looked right but actually wasn't.
This was a 10 second job for a multi meter.  I really need to find that...
Thanks for everyone's help!
People always misreport their capacitor values, don't worry about it. If someone says 0.22uF, chances are they mean 0.022uF. Especially if they buy their stuff from a guitar parts company rather than a Radio Shack equivalent.
I asked an artist's guitar tech what value he uses for the tone controls in the guitars, and he said "I'm pretty sure it's... point-twenty-two picofarads".
I'm pretty sure it's not - that's 0.00000022uF. They're quite hard to come by, I don't think turning the control would make an audible difference (certainly not a useful one).
It was for guitar so I'm guessing you're right.  Wired properly it works as expected.
